RZ/A Family¶
Supported boards in the RZ/A Family:
RZ/A3M
Run the Project¶
The RZ/A boards are MPUs with a focus on baremetal and RTOS applications. Projects are built for them using e2 Studio IDE, available for Windows, Mac, and Linux.
Clone the ready-to-use repository for your board:
git clone https://github.com/lvgl/lv_port_renesas-ek-rz_a3m --recurse-submodules
Downloading the
.zipfrom GitHub doesn't work as it doesn't download the submodules.Follow the instructions in the project README.md to build and flash the project to the board.
Modify the project¶
Open a demo¶
The entry point is contained in src/LVGL_thread_entry.c.
You can disable the LVGL demos (lv_demo_benchmark()) (or just comment them out)
and call some lv_example_...() functions, or add your custom code.
Configuration¶
Edit lv_conf.h to configure LVGL.
It will automatically run any demo that is enabled in lv_conf.h. You can see lv_conf.defaults for a summary of the configs which have been changed from the defaults.
Support¶
